Right Side saddle bag removal on 2014 RT ?
It might be easier to access that from the rear. To remove the side compartment you have to start with the mirror and work your way back.
doc... I need to run a wire to my radio which is located on right side under the passenger grab handle..
thanks,
osm
Much easier answer.
You remove the grab handle and the cover adjacent then the 4 screws securing the radio and it lifts out.
Once the radio is out you can route wiring fore or aft along the frame fairly easily.
Much easier answer.
Doc... is the above procedure for a 2014 RT limited ?
tia
osm
