You are a tire guy for a day job I thought. Not bagging on your comment, but I need to ask, if the road friction heats the tire, how could Ride On heat the tire. It may insulate the tire somewhat, but unless the tire is pushed to its limits, the insulated heat should not be an issue.
I suppose if too much Ride On were added it could be serious factor.
I live where it is warm or hot most of the year. I do not know the temp specs for Ride On, but since it pours from a bottle at room temp, it will flow easily in a cool tire. I could be wrong but thought I read it thickens with heat but does not solidify, so as the tire begins to roll the solution flows as needed, then "sets" as required.
Ironically, I am not a fan of these products and prefer a high end balance, but unless I removed the hub from our Spyders rear wheel it would not fit my dynamic balancer, so the rear does have one bottle of Ride On. My two fronts however are dynamic balanced with weights on multi planes and balanced on the fine setting to within .1 ounce.
Recently while at a dealer, we were talking tire balance. Never saw it mentioned here, but there is a tech bulletin for shops to take the static balanced front tires with weights on a single centerline plane and rebalance by dynamic method and place weights on two planes. I had to do this within the first week of ownership and long before the bulletin existed.
