Ride on
Pam, are you using the motorcycle or the car type? Or is there any difference in the two different types?
I have always used the motorcycle formula in my bikes, and when I ordered for the Spyder I instinctively ordered the same. After I installed it (and it works fine), it was brought to my attention by BajaRon that Ride On has one specifically for the Spyder. :banghead:
So, whenever I get new tires, I will get the Spyder formula. Not sure what the difference is, or if there is any. Like I said, the motorcycle formula is working just fine.
Pam
They recommend the spin balance not for the balancing aspect but to look for out of roundness and other structural problems. If you have a significantly out-of-round tire Ride On won't fix it.
My misreading cost me a little extra $ for the spin balance on all 3 tires.
It is..??
Isn't one of the big things that Ride On advertises is sealing the tire in the event you run over something? I believe that is called Ride On Sealant. I had Ride On in my tires, including my trailer and I hit a nail and my trailer tire went flat anyway. I don't use it anymore.
Think your right but being adverse to having anything movable inside my tires I feel the same...may never happen but don't want to be driving high speed and have my fronts start doing their own thing...:roflblack:
I just put Ride-on in my 2013 RSS this morning. I've had the Spyder in the shop twice in the last month trying to correct a bad vibration in the 60-65 mph range. So severe I could not read the small text on my instruments. After two wheel balances, a belt tension adjustment and a complete front end inspection, the vibration was almost gone, but not completely. I installed the auto formula and now the vibration is completely gone, except a very small twitch at 63 mph. All other speeds are silky smooth. The instructions do say to balance the wheels prior to installation, but I'm not sure what the motorcycle formula says. The only problem I had was trying to determine how much I had squeezed in because it sticks to the inside of the bottle obscuring the sight gauge.
If they do have a product specific to the Can Am Spyder, it does not appear to be listed on the Ride On Website. They cover everything from bicycles, to cars, motorcycles, atv, trucks, farm and so forth.
As for prebalancing prior to adding the Ride On media. Reading the instructions per Ride On. Automotive tires are to be balanced prior to Ride On application. Motorcycle tires are not balanced prior to Ride On application.
PK
If I want to add Ride-on to my Spyder what do people suggest.Remove the wheel weights or keep them on? :trike:
Quite a while ago when ride-on was first offered on this site there was a discussion concerning the wheel weights. There was no consensus, other than it doesn't hurt to leave them.
:agree: However, when getting new tires mounted I tell them not to put those ugly weights on my rims. They have even offered to put the Ride On in for me.:yes:
Pam
