While raising the ride height 1" or so is very unlikely to upset the VSS much at all, and could well be possible for someone like Mike ^^ to fabricate up something, I reckon you'd be a lot better off by increasing your ground clearance thru using taller tires rather than trying to lift the Ryker via the suspension, changing the Ryker's suspension & steering geometry, and risking all the issues/difficulties that can bring!! :lecturef_smilie:
Besides, raising the suspension might lift the body of the Ryker a bit higher, but it won't lift the the suspension arms & steering knuckles etc that are out where they are close to the tires - anything out at the end of the suspension arms will still remain exposed to hitting &/or catching on rocks, tree branches, mud etc, even if the Ryker's belly isn't scraping quite so much!!
AND you'll lose some 'down travel' on your suspension too, because it's going to be pushed further into the 'droop' cycle to give you the lift, possibly causing it & your shocks to 'top out' more often &/or hit the susp arm travel stops more often due to no more droop available; as well as increasing the pre-load on the coils and over-all, making for a much harsher ride!! :sour:
However, even without all those downsides,
there is NO easy way of correcting the camber if you raise the ride height via adjusting the suspension - you may well find the easiest way to correct and return the camber to something useable is to fabricate & fit a/market suspension arms; either adjustable or of different lengths/angles to the OE units! And
that might not be easy or cheap, unless you can do it yourself?!? :dontknow:
But it would probably be a fair bit cheaper and a whole lot easier simply to fit tires with a higher sidewall profile and instantly gain extra ground clearance for
EVERYTHING, suspension arms, spindles, steering, etc; albeit not quite so much lift for every 1" tire dia increase, and with possibly a minor impact on your Ryker's 'final drive' gearing - giving you marginally less low down acceleration that would be offset by a better top speed or lower revs for 'speed over the ground', altho your speedo might not reflect that, simply becoming 'more accurate' when compared to your 'actual speed over the ground' rather than showing anything different! And you might hafta use spacers or longer fender support arms to keep the fenders clear of the taller tires! But over-all, that should be a whole lot easier & cheaper to do; more effective at lifting
EVERYTHING without changing your steering or suspension geometry
AT ALL; and giving you an opportunity to pick a better quality &/or different/more suitable and stronger tire into the bargain! And IMHO, that's all round a whole lot better & smarter option!!
hyea:
So I'd be looking at fitting taller tires before
even thinking about lifting the Ryker via the suspension! :thumbup:
