Resetting the computer - Reset the Spyder
groundeffect
Registered User
Hi everyone.
I've seen this mentioned in a few posts now, but not sure of the exact details of the procedure...
1. What is the procedure for 'Restting the computer'? Details???
2. Why/when is this mode required to be done? What function does it provide?
3. How does one know the procedure has been completed - any indication from the Spyder or on the Cluster that it is now completed?
Thanks,
cheers.
There should be nothing that you cannot accomplish by turning the key on and off three times, to clear a past code and limp mode. If the problem remains, you need to see your dealer anyway. Either limp home or call for the flatbed. Theoretically, you can clear the computer (in part) by disconnecting the battery for a few minutes. I would caution against this if you are having problems, since it clears out any "occurred" codes, making troubleshooting by the dealer and BUDS harder, by wiping out the record of the recorded codes and their sequence. There has been talk of doing this to clear the ECM mapping, but there is much controversy over whether it actually does anything. My opinion is that idling for 15 minutes will provide the same benefit, if any, filling the table with new data. I wouldn't give it another thought. Other opinions may well vary.
