eddieshep999
Mine will be here tomorrow.
What type of marker are y'all using to mark the components? Looks like a paint applicator.
I used a white paint pen
Hello Spyder Friends,
Meg and I are heading to Valcourt this year, as many of you are. And we hope to meet many of you there.
I am the type that is always concerned about what issues with the Spyder can ruin a trip like this. Our Spyder has been flawless and has never let us down, but doo doo happens! nojoke The one flaw I keep coming back to is the windshield arm.
Many of you have had that arm break as many as 2 times, and it would really suck if it were to break on a trip like this. I had purchased the windshield arm from noboot (Ron), just to have in case mine ever broke. Then I started thinking of the interstate speeds we will be traveling at, and the stress on that arm. The thought of Spydering down the road with a windshield on my lap did not appeal to either one of us. And we always ride with it fully up, so mine has been stressed since new. With that thought in mind, we decided to change it yesterday, and have one less thing to worry about.
Ron provides great written instructions with the arm, but has an excellent video here
Followed all the steps in the video and all went well until it came time to remove that little screw from the end of the gear. Being a electronics guy, I have every type and size of screwdriver imaginable. A pozidriv Philips seemed to fit the screw well without slipping. The issue I experienced was that the screw was starting to break apart before loosening.:gaah: No doubt caused by the copious amounts of Loctite BRP uses on all their screws. Could not use heat to free the Loctite, as the plastic gear would melt. Rather then break the head off of the screw, decided to remove the magnet end. We marked the magnet well so after reassembly it would still be in the proper place.
We used a bearing separator from harbor freight, and placed it under the magnet.
We then flipped it over and used 2 screw drivers to pry the old arm and shaft up out of the magnet.
We would up using larger screwdrivers then shown, it initially was really stuck on there. Meg was holding the gear on top as I pried. I expected it to come off slowly, but it let go and moved quickly when free.
You can see from the paint marks, the plastic is engaged rather deeply on the shaft.
Installed the new arm following the steps in the video. Installed the magnet back in the bearing separator like this.
Gently used a rubber mallet tapping the gear and shaft back into the magnet.
Everything went back together well and worked fine. I would recommend using some tef-gel http://www.tefgel.com/contain.php?param=tefgel_infor as I did on the bushings that are in the aluminum windshield frame. The bushings are brass and the frame is aluminum and they were a little tough to get out due to corrosion from dissimilar metals.
Hope this is helpful, Take Care, Louie and Meg :riding:
So I went to Harbor Freight on Sat afternoon. Bought the Bearing splitter kit as the only single small one they had was in the kit. Spent $54.00 on it. This morning tried and the magnet popped right off. Hallelujah!! Put the bike back together and all is well. The only other problem I had was when I popped the cover off of the magnet side of the lift mechanism, it flew into the big hole just above the unit. Try as I might, I could not find it so, I fashioned a piece of plastic about the same size, drilled 2 holes and put it on in it's place. I figure all it does is keep dirt off of the magnet. Seems to be working well. Thanks for the info.
Can't remove the cover that the risers go through. All risers have a sleeve in them that won't move, and they won't separate from the cover which has to lift through the risers.
Noboot, where do I look for the crack on my 2015 RT and do I need to remove anything to get to it? ThanksIt doesn't matter if you go the magnet end or the worm wheel end as long as you take it steady and take your time It ends up with the same result, a safer better fitting arm that won't break like the OEM ones do.
Anyone with an RT should regularly (maybe while drying the bike after a wash) look out for the tell tale sign usually the crack. I went to one Spyder Rally and seen 11 RT's with a minor crack in the arm.
How may I contact you to order the replacement arm? Thank you
He's top notch and makes a great product!!! It's worth every penny. :thumbup:
I was riding today and all of a sudden, the windshield collapsed. When I got home, I notice the part that raised the windshield was broken in half. I looked on-line for the part but, they don't seem to sell this part. So I'm in the process to fixing this part, hope it works. I can't understand how this piece can break like that, it is made strong.
