Replacing a battery on a 2017 F3-Limited
JimH
How difficult is it to replace a battery on a 2017 F3-Limited? Removing the frunk it looks like it is packed in there pretty tightly.
Thanks in advance.
Jim
Its easy! open the frunk lid. There is the black cover below the headlights. It just pulls off straight up and out. Then remove the tub. There is 4 push pins holding it in. Remove the pins and leave them out. You don't need them. makes it easier to do maintenance on battery. Pull out tub and there is the battery. Remove terminal bolts and hold down bracket. Remove negative first then positive. Install positive first then negative. Don't want you arching the battery.
