Replacement Key
Tec35
My used 2017 F3 limited finally arrived from Florida today. It only came with one key(which I knew about). I would like to purchase a second key or have one made. I am a little confused on what I am reading, do I need a new ignition or a key programmed? What is the best way to get a new key. Also, I do not have the key sleeve with the numbers on it like my 2019 F3. The previous owner never turned them or 2nd key in.
goto dealer get a blank key, have them program it, if they can't cut a key, goto a lock smith for duplicate pattern on your exsisting key
you can also buy a Ilco blank key, just have it cut to pattern for ONLY front and back locks - non start key
Thank you for clearing it up.
I'm pretty sure you have to cut the key before it can be programmed into the DESS since it has to be in the ignition with the bike turned on. The key doesn't actually get programmed. The key ID number is entered into the DESS as a valid key. That has be done with BUDS.
Thank you!
If you want a spare key that will do everything but allow you to start the Spyder, the Ilco blank you want is an X270. If you bevel it as shown in the picture it will allow you to push the key fully down in the ignition switch to unlock the frunk.
Only because I'm a tech geek and researched this a lot - MINOR clarification: On the 1330 motored Spyders - the Key is actually programmed into the ECU - the DESS just reads it and passes it to the ECU for verification. This allows the DESS to be replaced with no BUDS needed. You are correct in everything else - a new key needs programmed with the bike on - into the ECU using the BUDS.
The older Spyders the key was registered/verified in the DESS itself - so a DESS replacement meant BUDS and reprogramming keys.
You are so correct! I was so focused on the OP's reference to his 2017 RT I didn't even think about the change made from 2013 to 2014. Thanks for clarifying that for those who may not know. 2013 and earlier keys also could be cloned. 2014 on cannot. At least I don't think anyone has come up with a way to do it. That subject has been quiet since 2015.
Dealer blank key $50. Have the key cut $5 or less. Dealer progrem the key $25. Just had mine done a couple of weeks ago. I ordered two keys because I know I'm bound and detrmined to lose another key.
Thank you that is good to know. Again Thank you to everyone for all great info. I reached out to the dealer they do not cut the key, only program. They will send it out to get cut but he told me better off having it cut myself and bring the key in already cut, cheaper.
2dogs did you order your blank key online or through the dealer? I am assuming through the dealer
Minor correction. All models 2014 and later, no matter the engine size, the ECM handles the verification.
you could also have DESS turned off and not worry about programming keys to the bike. The Ilco flat key will also start the bike. I keep an ilco spare in my billfold....just in case of a senior moment.
:lecturef_smilie:Be sure see who they use to cut key, most any won’t cut chipped keys from somewhere else:sour: my experience anyway.
The online key was only $4 less than what the dealer wanted. So I purchased them from the dealer, I like to do business locally if at all possible. I had the blanks cut by a trusted lock and key shop, otherwise, it's a crapshoot if the keys are cut wrong. If the dealer will send them out to be cut it will likely cost more but if there is a mistake and the key is cut wrong, maybe the dealer will absorb the cost. You may want to confirm that with your dealer. Good luck, it made me kind of nervous too.
Thank you, that is a good idea and worth the little extra for a piece of mind. Btw I saw both of your response good advice thank you
I bought a replacement for a lost key and had it programmed at the dealer for $42 total. Maybe they felt sorry for me, I'd only had my Spyder about 2 weeks.
You got a good deal. Hang on to that dealer. Whenever my ride goes into the shop I always drop of a 12 pack of soft dinks or gator aid before I leave. The shop guys give me good service, now the service manager is another story. BS doesn't sit well with me.
