Replacement Front Rims
Brunswick
Can anyone recommend a set of reasonably priced replacement front rims for the Spyder? I want something the same size and bolt pattern, but where the spokes of the rim don't protrude past the tire like they do on most stock RS rims. Thanks.
Unfortunately, if you want to keep the same width or offset, you have to do something to clear the brake caliper. From what I understand, the RT wheels do not protrude quite so much, because offset is different. I chose to change both the offset and width, so the rim doesn't protrude at all. From the way it sounds, I think the RT wheels will be your best compromise at this point. I've seen the RT wheels on ebay at an affordable price.
