Removing Plastic Rivets
rhoule1
Coming up on my first oil change and wondering about removing plastic rivets. Do they just pull straight out and are they reusable.
Thanks
Roger
Pull (or carefully pry) the center portion out until you feel resistance...about 3/8"-1/2". Then you can pull or pry out the bottom portion. You may find it is easier if you wiggle the panel a bit. If it won't come, you can completely remove the center portion, then replace it after the bottom is removed. To reuse, insert, then push the center home to lock the rivet.
:agree::ani29:
:agree:
Also notice that the "retainer" (middle part) is indexed kind of like a "Z" so it goes back together with the "insert" (outer part) just one-way. And NEVER force a plastic rivet or you could cause unsalvageable damage to it. The use of a thin flathead screwdriver seems to work best for removal of the retainer.
Good Luck!
