Removing heated grips
amusher
I'm wanting to put risers on my 2012 RS. How do I remove the heated grips and put them back on the new bars?
Hard to say without actually seeing your setup......However, Unless they were glued on (sometimes you have to do that to keep them from sliding), I've always had good luck using an air compressor. Blow compressed air into the grip between the grip and bar and work them off. The air will "inflate" and separate the grip a bit from the bar.
