removing BRP lower belt guard.........how?
OK, nothing critical and sounds stupid I know, but......... what I found was that the 3 nuts (that you can't see or actually hold) are spinning while I'm turning the bolt head. :banghead:
Don't think getting a wrench up in there to hold the nut is possible. :dontknow: If so, what size wrench/socket fits? :dontknow:
I'm looking to add a few washers to bring the "plastic" out a little because it does appear it has lightly rubbed the belt/sprocket edge at some time.:banghead:
appreciate any insight.
Oh yeah those are a pain. Try lifting the bike up a bit to get your hand and wrench in there. I think its 10MM. Think only one of them had a washer to keep the plastic away from the belt.
I did this a long time ago, when I put a home made belt guard on, and :agree: it wasn't easy .... if you can jack it up it's a lot easier to do ..... good luck ... Mike :thumbup:
