Removing Bolts with the dreaded spring clip keeper
bluestratos
I have a heard a few folks having difficulty with removing these bolts when there is a spring keep. Take a small screwdriver (Jewlers size) and push it in the hole next to bolt after the nut is off. You can then back the bolt out by hand. I did not install the keep when I put it back together.
Regards,
Randy
Regards,
Randy
What bolts you referring to.....
My bad, these bolts hold the lower pans on, on under the oil resevoir and one on the skid pan under the rad fan.
Sorry about that,
Randy
