Removal of panels - What tool????
All the tools you need to do a lot of the work on the :spyder2: are either under your seat ( RT model ) or in the frunk of the RS. You need to look in your manuel as to how the panels remove as some of them you just pull off while others require the torec screwdriver or the removal of push-pin devices .
push-pin devices
Don't remove those they hold studs that attache to grommets...:lecturef_smilie:...
Freebob...:doorag:
If this is your first time digging around under the Tupperware I'd suggest pulling out your manual and spending a couple of days digesting the section on panel removal...:thumbup:
Hubby, has the panels removed now thanks for the help on that and the manual.
We have the GPS wire threaded and ready to hook to the battery. Hubby is going to see about getting GPS sound in the helmet too.
14 days to go till our trip to Niagara Falls, Americade. :ohyea:
What tool does it take to remove panels from the :spyder:?
Picked this up at Lowes. Kobalt racheting driver with torx, slotted, philips, allen head assortment plus 8 + 10 mm sockets. 5 more SAE sockets also. $10.00 for the little kit.
Pretty good quality for the money and has a nice little case also so you can throw it in the trunk. Added a 10MM box head wrench for $2.75.
The stuff in the tool kit is kinda junkie. Air gauge seems to work OK though.
