Reflector?
yooper
How does the red oval reflector on the rear fender support attach? Is it just taped on? Mine got a chip in it and needs to be replaced.
I've found that dental floss works wonderful to remove emblems that are attached with adhesive. Tough buggers may need some added heat from the hair dryer then work at it with the dental floss. Watch your fingers though, if you get sawing at it too good the dental floss tends to cut into your fingers. Ouch!
