Red Dust front sprocket
We have a 2016 RT-L with 23,700km (14,700miles). During my spring pre-season check, I noticed red dust starting to appear of the front sprocket.
A few questions...
- Is the RT and F3 front sprocket the same part #. In reading the forums I believe the new part is #705503244
- Is there a TSB or something from BRP which I can ask the dealer to reference in case they are not aware of this issue?
- Does BRP cover the cost? My warrantee is expired, but BEST is still active
- In following the new install procedure using Moly Paste, can the bike be ridden immediately after installation or does it need to cure? (My dealer does all service while I wait since I have no way to get back home)
Thank you for your advise! (I am unable to do the repair myself).....Brian
Yes, you can do it yourself if you know which end of the screwdriver is the handle.
+ With the parking brake on, loosen the pulley bolt.
+ Lift the rear wheel off the floor and release the parking brake.
+ Walk the belt off the rear pulley. Some loosen the axle and run the adjusters in, but I'm lazy.
+ Remove the pulley bolt and pulley. If pulley sticks, use a puller.
If pully sticks squirt down the splines with a release oil or kerosine or anything thin and oily. I tried levers, hammer and all sorts, finally gave it a skoosh of WD40 and went off for the puller, came back and off it slipped like magic - still amazed to this day how the rust dust wedges up solidly.
1 = yes
2 = Updated torque 111lb/ft (Personal opinion, at least that torque, I use higher! This is the key to it not happening again.)
3 = Seems to depend on your dealer relationship with BRP.
4 = You can drive it straight away, there is to setting or curing involved.
1 = yes
Is the new bolt a 12.9 grade bolt? My 2018 has a 10.9 grade bolt and specs for a 10.9 grade 12mm bolt is 77 lb ft. My pulley slide right off and appeared it was installed with while lithium grease. I cleaned it all up and coated with moly paste. Will have to torque that bolt once the wheel in reinstalled with the new tire.
