SPYDERJERRY1
I'd like some recommendations for 2020 Spyder RT Limited "wind deflectors". The highway buffeting is terrible. I'm going to get 28in. windscreen, but I want to add deflectors also.
if you buy the F-4 windshield, you can buy the wings that attach to it and they are great
www.f4customs.com
cruzr joe
I guess I'm fortunate, I have not experiences any buffeting with the OEM windshield and fixed air deflectors. But I am thinking about buying the OEM adjustable deflectors to try to get more airflow in hot weather.
The adjustable deflectors do help cool, but mostly with air to the legs. They are a little more 'leaky' in the cold. That being said, I like mine.
That's only for the F3T/Limited. The RT windscreens for the RT don't have that option.
OP---I'd recommend the OEM upper and lower wind deflectors. They replace the stock units and work very well. They're also adjustable. They look MUCH better than the Baker Built deflectors but honestly probably don't work quite as well.
I also have the OEM adjustable upper and lower air deflectors and concur with DanDanTMM that they will increase the air buffeting when open but for me I just raise the windshield a bit, I am 5'10" and for me personally they a huge game changer when it gets hot out, air isn't deflected directly at you,who wants 75mph air blasting you directly in the chest rolling down the highway? To me the air when deflectors are open seems to be a swirling right in front of you, I find them awesome in the heat.
What's your experience with the OEM adjustable air deflectors in cold weather? Do they help?
Do I read this to understand the lower wings probably do more for diverting cooler air than the upper wings? I just purchased my RTL about a month ago and have not ridden much in warmer temps (probably 75 degrees f tops), but I already feel there is a need for more air movement - even with the shield all the way down - which is how I normally ride. Too bad I missed the Black Friday sale at BRP!On my 2021 RT-L I keep the stock windshield in the lowest position (I'm 5'8") and I have the adjustable OEM deflectors. With the deflectors in the closed position I don't get any buffeting unless I am going over 60 mph but it is not enough that I raise the windshield. This past weekend it was warm enough that I opened the OEM deflectors and I immediately noticed the pressure behind the shield changed and I get some buffeting. Still not enough to raise the windshield but I noticed it immediately and raising the shield did help. I will say the adjustable deflectors don't redirect air onto your torso like the Baker wings did on my Goldwing. I ride with a mesh jacket and with the upper deflector open I feel more air on my lower sides and lower back (no backrest). There is some additional air flow on my torso area but it is subtle. The upper deflectors just don't turn in enough to direct it to your torso. The lower deflectors put wind on your legs and help move engine heat off of them. I have not ridden with a passenger yet with them open to give you any feedback from their perspective.
:agree: DanDanTM is pretty much spot on with my experience.On my 2021 RT-L I keep the stock windshield in the lowest position (I'm 5'8") and I have the adjustable OEM deflectors. With the deflectors in the closed position I don't get any buffeting unless I am going over 60 mph but it is not enough that I raise the windshield. This past weekend it was warm enough that I opened the OEM deflectors and I immediately noticed the pressure behind the shield changed and I get some buffeting. Still not enough to raise the windshield but I noticed it immediately and raising the shield did help. I will say the adjustable deflectors don't redirect air onto your torso like the Baker wings did on my Goldwing. I ride with a mesh jacket and with the upper deflector open I feel more air on my lower sides and lower back (no backrest). There is some additional air flow on my torso area but it is subtle. The upper deflectors just don't turn in enough to direct it to your torso. The lower deflectors put wind on your legs and help move engine heat off of them. I have not ridden with a passenger yet with them open to give you any feedback from their perspective.
You should look into Wind Wings. https://www.windwings.net/ They were a vendor at the Spyder Rally in Deland, FL a few weeks ago and I have to admit, I was pretty impressed with their product. Check them out.
