recalls?
Arguss
OK so a friend of mine just informed me that My 2008 RS has recalls out on it? But only place to take her is a Can Am dealer By BP. So where do i find out what recalls are out and where to take her?
Arguss
Arguss
Call a Spyder dealer give then your Vin # they'll run the numbers, and let you know what recalls should be done. If any.
Bob has given you good advice. The dealer can look up your VIN# and tell what has been done and what hasn't. To find your nearest dealer, you can visit the BRP Spyder website. http://en-us.spyder.brp.com/dealer-...g=-92.3700769&zoom=4&tabId=dealers/dealer_all In the US, safety recalls are issued through the NHTSA. To search their recall database, see the NHTSA website. http://www-odi.nhtsa.dot.gov/recalls/recallsearch.cfm
Not all defects are handled by the recall process. A recall is generally issued to address a safety defect, and all vehicles meeting certain criteria are included. This is usually done by recalling all vehicles of certain makes/models, within a specific production period. Recalls are tied to the vehicle VIN#.
Other problems are handled by the manufacturer and dealer through the use of technical service bulletins. These may address an entire group of vehicles or just those exhibiting a certain problem. For BRP, the Warranty Campaign is their most common type of TSB, although there are others. These must be looked up by the dealer. The tech will commonly do this when he hooks your Spyder up to BUDS (the BRP diagnostic system), but the dealer can look up your VIN# on the computer to see if any warranty campaign applies to your Spyder. Unless you actually show the problem listed in the TSB, the dealer may not perform any work, though. Occasionally a vehicle will be covered under a TSB but it will not show up on the computer. In those cases, if you have the problem, the dealer may have to refer to the hard copy to see if you are covered. This is getting to be less prevalent as BRP's system improves.
