Here's the latest addition. The rear wheel and pulley to match the fronts. The tire is a Toyo R1R 245/35-17 and the wheel is a 17x8. I don't have much clearance between the tire and the belt, but I'm going to put a 5mm wide spacer between the wheel bearing and the pulley spacer. There seems to be plenty of room to get it in there and the axle will support another 5mm of spacer width. There should be plenty of engagement between the pulley and wheel dampers, so I should be good there. I'm also confident that the brake caliper will align on the rotor as well as stock, because the outer spacers will not be changed. The measurements indicate that my belt alignment with the front and rear pulley will be okay. It will be pushed out a bit on the front pulley, but since the original belt tolerence on the rear pulley goes out to 5mm, I should be close. I'll have to make sure the belt aligns to the inside of the rear pulley at the 1mm inside tolerence.
I know this is not ideal from an engineering standpoint, but it's worth it to me to have what I want. I'll have to monitor my bearings and other wear items. Just wanted to share!
