I found that this helped on a 2011 RT. Do not loosen the axle adjusting screws and you won't have to worry about readjusting belt tension or alignment. After you thread the belt back on the pulley use a ratchet strap through the wheel and around the shock mount to pull the wheel forcefully forward. Then tighten the axle nut.
To push the rubber cush drive back into place use baby powder on the rubber.
There is no need to loosen the lower shock bolt and no need to remove the stock upper shock guard. The motorcycle shop was able to spin balance the wheel to perfect with one oz. of weight. Hope this helps someone.
