Rear wheel bearings
AnthonyG
Administrator
Staff member
I have noticed a few comments from people on replacing wheel bearings when putting on new rear tires - is this an issue I should be looking out for? Reason I ask is that the drive belt does not always stay at the same place on the rear pully no matter how well I adjust it and different tension doesnt effect it - wanders 3-5 mm when I stop to check at different times - could that be wheel bearings or swingarm bearings going bad?
this is exactly what mine did when my bearing blew, the top fell out when I took the seal out.
When you put your bike up on a jack and run it in first you will hear the bearings clunk and that means your main bearing in the sprocket is shot.
If you do it yourself you will have to heat the whole sprocket up and push the race out, if the bearings themselves fall out you will have to them in and with th center and flip the sprocket over keeping the bearings in so you can use it to push the race out.
3-5mm is more than normal. They will all wonder a bit but that's a little much. Could be a bearing but you should be hearing and feeling it if it's that bad.
