agedbikeman
Does anyone have any old RT rear wheel bearings, if so is there a number or letters and numbers stamped on them, if so can you tell me these numbers.
The reason I ask is I am told by a bearing specialist that all bearings have a number that relates to therir size, the number is intenational so whatever number you buy in whatever country, that is the size.
My RT has done 40,000 miles and I want to be prepared. I would like to use SKF bearings that are reputed to be the best in the world.
Whatever bike or machine I have had I have found this number system to be true, I order by number from said bearing specialist in UK and up comes the correct bearing every time, of whatever make or quality I want.
Had my wheel out last week for new tyre, but bearing numbers were stamped on underside so not visible
Thanks
Alex
Thanks
Alex
