Sue...there are posts here about using the 45 degree on all tires including the rear...same post mentions that the 90 does not work though. Was just reading through the post a week or so backAny chance this will work in the rear rim? Would it make it easier to check air?
.:gaah:....To clarify the ONLY thing that will work and be of any benefit IN THE OEM HOLE would be a STRAIGHT EXTENSION..........PERIOD ............I have re-placed THREE air valves on my various Spyders rear wheels with some 85 degree metal mtc valves from " KURVEYGIRL ".........( there are no 90 * that I know of )........This requires DRILLING a new hole on the opposite side of the RIM ( usually done when doing a TIRE CHANGE ).........YES you could do a 45 * , but WHY when the 87 * works better ???????.....MikeSue...there are posts here about using the 45 degree on all tires including the rear...same post mentions that the 90 does not work though. Was just reading through the post a week or so back![]()
.......Just curious...... the 85 degree air valve I mentioned above cost $ 5.00 ...........Your Item cost how much and do you need to own an Air Compressor ??????...........................Mike :thumbup:Get one of these and you won't have to change any valves, very easy to check pressure with OEM valve
http://www.toolaid.com/content/truck-tire-inflator-dial-gage
Here is another option.
http://www.harley-davidson.com/store/valve-stem-extension
It's only $10.95 and should make things easy. They'll deliver it to your local HD dealer with no shipping charges, then you can pick it up. I actually got some nice compliments on the Spyder in the HD parking lot. I found out about it on another SpyderLovers thread.
Full Disclosure: I read the reviews just now. There are six - three of them give it 5 stars and three give it 1 star. The three bad reviews say it leaks too much air. The three good ones really seem to like it. I haven't used mine yet. Anyone here have experience with this item?
I have one of these, under $5 Amazon or Ebay
:yikes:....I give in , Please DO NOT get the $ 5.00____ 85 degree air valve. It's way to simple a solution , it's far to in-expensive to even consider after spending $30,000 on your Spyder and you don't need to BUY a compressor to make it useable .....................Whatever .......Mike![]()
_____:hun:......REALLY: MINE RISE IN PRESSURE EVERY TIME I TAKE IT OUT FOR A RIDE !!!!I prefer this inflator:
http://www.amazon.com/gp/product/B002PUTC0M
It is accurate to 0.1 psi so makes getting the front two tires balanced a breeze. And with the chuck it has, the stock valve stem works great.
The problem with the stock stem is your chuck, not the stem.
Oh and BlueKnight911, yes, owning a compressor is needed to check and fill tires. Where else is the air going to come from? They don't rise in pressure over time, they loose air. Getting the right pressure is also much easier to fill just above the desired pressure and release small amounts until at the desired reading.
Yes, good tools cost a few $$. I love tools.......
:dontknow:...Just taking a wild *ss guess, but I'll bet 90 % of all Spyder owners don't own a COMPRESSOR..........So where are they getting their AIR ?????????.................a gas station ....................Mike :thumbup:
actually this red neck does own, a couple, &number of proper tools to go with.[emoji12]
