You really
CAN NOT tell if a tire has got the right pressure in it by looking at it!! And that applies
even more so for radial tires!! The 'look' of the bulge in the sidewall can be very deceiving and completely at odds with the pressure in the tire. So
PLEASE, don't ever rely on how your radial tires on
ANY vehicle
LOOK!! At best, it could cause wear &/or ride & handling problems; at worst, it could be deadly!! nojoke . :lecturef_smilie:
As to the 'correct' pressure, unless you & your load on the Spyder/Ryker is WAAAY outside the 'normal range' of users, then for most 'real' auto tires (ie,
NOT Kendas) with speed & load ratings that meet or exceed those shown on your Spyder/Ryker's tire placard, then you are probably going to be fine running something like 16-18 psi up front, and say 16-20 psi in the rear - bearing in mind that a larger sized tire generally needs a little less air in it to carry the same given load. So if you run 18 psi in a 165/55R15 up front at 18 psi, then swap to a 175/60R15 tire without changing your usual load, 16 psi is probably going to be a better choice in that larger tire. On the other end of the Spyder/Ryker, swapping out a 225 wide tire for a 205 wide may require an extra 2psi or so; but if you go up in profile at the same time as going down in width, that need for 'extra air' may be negated. I've recently swapped from a 225/60R15 tire that ran & wore very well at 16psi to a 205/65R15 that I'd normally expect to need saaay 18 psi instead, except the higher profile & the differences in 'actual' tire sizes vs nominal sizes has shown the new tire is actually a tad
larger than the old tire so the optimum pressure for the new tire is also 16psi! :thumbup:
But regardless, I very much doubt that there is
anyone out there regularly riding a Spyder/Ryker that is loaded up enough to
NEED more than saay 20 psi in a 'normal' auto tire mounted on the Spyder/Ryker (car) rims (tall &/or very large riders like Peteoz may be amongst the exceptions that prove that 'rule'!
) Most 'usual sized' riders & loads will generally get a better balance of tire compliance with the machine's suspension and better traction, ride, handling, and tire life at something a bit lower, altho they may not be used to the 'feel' that those pressures bring, probably because they've become used to running on over-inflated tires over time/thru tire fitter's apathy or lack of tire pressure knowledge! Of course, there may also be some who knowingly choose to run more than 20psi in their non-Kenda auto tires fitted to a Spyder/Ryker, maybe to optimise fuel economy over tire life & suspension compliance, puncture resistance, or traction; or possibly simply because the've grown to like the 'firmer feel' that the higher pressure gives them; or 'thinking' it gives them more 'direct steering' despite the lack of grip those pressures usually entail; but that's their choice & prerogative, rather than strictly being a necessity for optimal tire performance.
If you want to search my old posts here, or look for info on the 4psi rule elsewhere, you can use that repeatable & measurable method to determine fairly accurately what is the optimal pressure for
YOUR tires on
YOUR vehicle in the current conditions/ambient temps etc when used & loaded the way
YOU do that, but it does take some initial effort on your behalf; there are also other methods that can get very close, too - chalking the tire & examining the tread imprint; wetting/painting the tire & checking how its track looks; or even weighing the loaded tires on each end & doing the load/pressure calculations using the tire manufacturers supplied load/pressure info.... but with all the many & varied methods available that I've tried, I've found that for the vast majority of Spyder/Ryker users, they all come back to ending up pretty close to the same pressures mentioned above - 16-18 psi up front and 16-20 psi in the rear, with a few exceptions for special needs &/or applications (eg, go higher if you really want to spin the rear tire & light it up at every set of lights....
) Of course, you may choose to use pressures outside those ranges for any reason you like too, but in doing so, just be aware that it is very likely that you
WILL be compromising
some aspect of your tire's performance by doing so. :lecturef_smilie:
Or you could simply set your tires at whatever pressures you feel like, then
Ryde More, and Worry Less, and
maybe pay the bills later!
hyea:
Over to you! :thumbup:
