I believe I read that more time is spent turning left than right do to the fact that we drive on the right side of the road in this country. I tried to figure this out in my head but now my head hurts.cueman
Probably has something to do with that buttugly bag hanging off the right side. ��
Keep going :congrats: glad to see a high mileage Ryker out there. My rear tire (top) leans to the left. Will be in for the 3000 mile check up to ask why. Has always been that way.I have over 6,500 miles on my 900, I just took a look to double check but there is very little wear and it is very even. I keep my rear at 28 or 30 psi and 22 psi in the front. I would defiantly figure out the issue before I put a new tire on. I travel at highway speeds on curvy roads most of time. I would think I have more wear than I do. Maybe I'm just lucky. Also temperature is very cool here, 60 is a high most days.I wonder if the tire itself is at fault. P.S I used to live in Port Clint in the Buckeye state many years ago.
Crown in the road will cause this
I believe this is the cause. I tend to ride close to the right side, which would cause the left side of the rear tire to ride the right side of the crown. I guess I need to ride closer to the center line now and then to equal it out.
If this " theory " is true …….then all spyders would suffer the same wear ….. and that is just not the case …… I think there is something wrong with the rear alignment …… Mikehyea:
It must be a dog to steer if it's that far out! I'd start at the front alignment.
Not saying that there might be another issue, but. That is closer to reality than you think. If that bag is loaded heavy, it will take weight off the left side of the tire. The tread will scrub on the opposite side of the lean of the bike. Same thing happens with a truck with dual wheels if the tires are not matched diameter, the smaller tire will scrub off the tread faster. So keep your load as equal on both sides.
I have the 600 with about 800 miles on it. I notice today that the rear tire is wearing faster on the left side. Is there an alignment adjustment for the rear tire?
Not really. It's very stable and corners well.
