Rear speaker grille question ..
HayRog
.. what's the process for removing these grilles without breaking anything ?
They're flimsy looking and --- you know ;)
Thank you guys :D
Are you talking about the front on an RT ????????? ...... If so, if so I would go and look at a Fiche' at cheap parts or Procaliber.com ....... and examine the Pics of the grills out of the Spyder and you will see where the Plastic tabs are ( on the sides of the grills ) ....something thin and DULL can help you pry them out .....two tools help so you can one in so the tab doesn't re-connect............ good luck ....... I've had mine out dozens of times, so far none have broken :clap:...... Mike :thumbup:
The title of his post is [h=2]Rear speaker grille question ..[/h]
