Rear shock
Cindi
My rear shock loses air until the pressure reading is zero. Is this normal after not being ridden for a week or two?
No way..!!
you may lose some but never down to zero. Have the dealer check it out though it does look like a leak in the system.. :gaah:
Before you run off to your dealer, get a tire valve core tool for a couple of bucks in the automotive depatrment, and tighten the valve core in the Schrader valve under the seat. thagt is the most common source of leaks. You can test it with a little spit or soapy water. Other leak sources ate the air bag or the air piping, or the air release solenoid valve (on the RTS or LTD). Your dealer is best equipped to handle those, but air bag leaks are generally not warranteed.
I have been having trouble with air leaks for a while.It got worse, leak down overnite. In the shop now to replace the unit. Not sure how much
Oldmanzues
