Rear shock on 2011 RT
Questions
I wonder if anyone else has had this problem. I would be riding in a group and another rider would tell me my spyder didn't look right going down the road. I admit it seemed a little funny with the steering, but I laid that to being new and my not being used to a different type ride,so I assumed that they were ribbing me because I wasn't as steady as I should have been. I also had the same heat problems as all the other riders so purchased the cat shields. We installed them Sat morning and when I jacked up the rear found that the factory had not installed one of the bushings that keep the shock centered on the bolt. The inner bushing was wadded to the side and the shock was all the way over to the driver side. We forced the shock back to the right position and the rear attitude of the bike changed, and what a difference in ride till it went back over to the driver side. Called my dealer, and they have ordered the bushing to replace all if them. So maybe there are others out there with similar problem. Just saying...
RT rear shock
I absolutely hate reading stories like this.
While it shouldn't have been allowed to leave the factory that way, the dealer certainly should have caught it.
Well I guess the lesson for me is that I should have gone over it myself, but all the bikes I've ever had I never ck'd on delivery, oh well they are going to fix it but that takes riding time away
So will no response to this question either mean that no one has read this thread, no one has had this problem or that they have read this thread and have decided not to answer? I for one have not had this problem.
Chris
RT shock
Chris
I hope that mine was the only one that came thru this way. Course maybe others are going to ck theirs when they get a moment. Glad yours is correct
I was there when the poster discovered this on his RT. I'll bet that shock was centered when it came through the dealership and shifted after it got a few miles on it on the road. Without the spacer bushing on one side it probably stayed centered for just a little while. It would have been real easy for the dealer not to have caught it when it came out of the box if it was still centered then. It's BRP's lack of QC that bothers me. 3 of us bought these in town this year. Mine leaked anti-freeze as did another with clamp problems. One did not have the rear hand grips pluged in under the battery cover panel one came with a defective battery that caused problems from day one and has now been replaced. .. and one now has this shock problem.
Rear Shocks
Not sure if my 2010 RT had this problem or not, because at about 800 miles the lower rear shock bolt fell off while going down the interstate. They changed the rear shock, swing arm, wiring harness and air bag and then at 2000 miles the new rear shock went out.
RT shock
I can just imagine that woke you up, then to have the replacement shock go also...bummer... I've heard of quite a few shock failures but not like you had
I'm on my third rear shock on my 2010 RT. I lose dampening. It affects the handling and is quite noticeable. Back end start to bounce. We ride two up so once in awhile I lower rear shock pressure to see how the dampening is by just pressing down on the rear grab handles.
Rear shock 2011 RT
I replaced my rear shock myself.
Wrapped around the shock was a paper that stated the warranty on the shock would be valid only if after installation the rear suspension was re-calibrated by BUDS.
I assumed this was meant for the RT-S model and those RTs refitted with the air suspension.
Because of this, I wonder if it is possible to wreck the shock through a combination of airbag pressure & load.
Perhaps it might explain the rather high incidence of shock failure (loss of dampening)?
That's a good possibility, Thanks, I think I will see if they have done that re-calibration
It is my outside-looking-in opinion, without having suffered a shock failure, that many of these are caused by the shock topping out repeatedly. Too much air pressure in a manual system, or too high a setting on the automatic rear suspension could do that, especially on rough road. Improper ACS calibration could, too. Warranty Campaign 2010-006 had a revised ACS calibration procedure, as well as a warning against overfilling the manual suspensions. If the dealer does not do the ACS calibration by the new procedure, failure of the shock is more likely.
All very true, but I'm working on my fourth OEM shock, and I'm confident the ACS calibration was done correctly.
There could well be other factors, but your situation is not the norm. There have been others with repeated failures, but not many. Most RT owners have had no failures at all, since the ACS calibration issue was satisfied and the shock engineering was changed. There has to be a common reason for the handful of continuing failures. The problem lies in identifying it.
To much?
Well, my RT is a manual fill air bag and I always run 70psi two up and if loading up with gear put 80psi. They say the rear air has a max of 100psi and I am not that high and BRP has not warned me other then max pressure. I had heard a noise guess it was topping out but only about 2-3 times. If that is a problem then we should be told by BRP about that. I find a firm suspension is better for me. I have seen a RTS with only 24psi in the rear and the owner liked it, a Buick ride I guess.
