Rear pulley Group buy? Which manufacturer?
Got it.:doorag:
I like to get off and stretch my legs around 140 miles so that's not a issue with me. I do get a little better mileage than you're getting too so that helps.
The Aprilia sportbike it came from can rev but has 6th gear also. I find the Spyder easier to back up than a motorcycle so i would give up reverse for the sixth gear but this might create harmonics with the belt or other components as the load and rpm range will change. Still, I would like to try one witha sixth gear like the engine the spyder came from
Is the 6th gear on the Aprilia an overdrive? If not then the end result would be the same as we have now.
...Too bad we can't have reverse AND 6th gear-BRP, are you listening?
My thoughts exactly. :thumbup: Didn't some bike use the starter as a reverse motor?
If they kept the current 5 gears and could add a sixth on top, like an overdrive. :thumbup: There are still times that I feel myself wanting to upshift once more while cruising but find I'm already in fifth.
