Imnotlost
I am about to rewire my wife's 2012 RS LED ground effects and found a promising source at the rear fusebox. There is an open accessory (40a) socket with fuse, but there is no connector/harness that I can find that plugs into it.
My questions are;
1) Is the harness & connector stowed somewhere?
2) If it is not, does anyone know a good part number for that connector so I can order it from BRP?
I prefer to use this fuseblock as the source because it is closer to the battery which will help when I decide to get the FZ-1 fuseblock and make this my switched 12v feed (assuming the accessory is switched)
Thanks!
My questions are;
Thanks!
