Hello all, new here and looking for some help. I have an '09 RS SE5 and the rear cylinder is not firing. I have checked all the basics, injection pulse, spark, and compression are good. I have taken the valve cover off and there is no visible damage to the cams and the valves appear to be moving as they should. I think this model has stability control, but I can't find any info on how it works or what it does. Is it possible that has failed and is causing the cylinder not to fire? Any ideas would be greatly appreciated, thank you.
