Rear break caliper plate
Sun-_-Dragon
Just did tire replacement on my 09 gs se5 i took the two bolts out and removed tire when i went to put it back on i noticed a plate that i didnt remove i relise its for the break caliper but only mounting is a peg on back of swing arm and what looks to be hole to fit the shaft through is this how to remount it with shaft through the plate ?
I just did the same thing. I didn't pull the plate off, it just kind of fell off when I was pulling off the front wheels. The axle goes thru the big hole and there is a stud on the inside of the swing arm that the slotted hole fits over.
Yup. You're doing great keep going. You will have to fus with it a bit to get it aligned so the axle will slide through.
