Rear brakes change on 2010 rt whats the best way to compress caliper to install pads
They're actually pretty easy... I have this honkin' big old screwdriver, that I'd fit between the pads, and give a quick twist... :thumbup:
Remember...
if you added brake fluid at any time you may have to remove some fluid or watch the reservoir for seepage while compressing the piston. All the above work well for compressing and make sure no one steps on the brakes while you have them apart...:thumbup:
Yes to all of the replies
All spot on! Lastly, make certain the parking brake is off and disconnected. (:banghead:)!!!!!
