jlc41
Warning axle nut cotter pin missing
I just want to FYI all, I have a 2018 Spyder & my drive belt was up against the flange. So I took a look see if I could adjust it. In so doing I discovered that the cotter pin is missing. Furthermore, the hole for it was not drilled through the shaft. I took it to the dealer, and they aligned and drilled the shaft for the cotter pin. They could not believe that a flat nut with no lock washer would not have a cotter pin. You may want to check yours out I'd hate to think what could happen if that nut comes off at speed. Ride safe everyone.
Joe
Joe
