hi
all of a sudden, when i try to adjust the rear air suspension, it wont go up anymore
i was able to lower the suspension but now it is stuck to the bottom,it wont go up when i hold the button
anyone can help?
Adjustible Controlled Suspension (ACS) has to meet the fallowing criteria to function:
- Engine Running
- In gear (forward or reverse)
- Park Break Released
- All rear compartments closed
I'm sure you know this, but one missing item and she will not function correctly. That being said, I've come across a couple RT's with a failed resister within the switch assy sub-harness. The resister can be purchased and replaced (requires sub-harness surgery). The units I found were under warranty, so the sub-harness assy was replaced...
ShawnFZR
Photographer & Technician
BRP Can-Am Roadster Certified Technician
www.spydertechnician.blogspot.com
www.spydertechnician.com
www.shawnsmoak.com
www.fzrphotography.com
Shawn, this for coming on our site. You at Pro Caliber in Longview,wa have been the best group of people to work and buy from. You have kept my rts running Great and I do tell all my buds to got to you for all their bike repaires .Thks you you great help, here and on your web pages to. See you soon.:yes::bowdown: This John, aloha,or red Rts 2012:clap:
hi
anyone can help?
Can anybody explain if having this disconnected was the whole reason the air suspension switch was not working and why the ride was horrible?
Thank you!
Put in the bolt. You should be able to rig this with a bolt/nut/washers until you receive the proper parts. Be sure to use a lock nut and/or loctite so you don't lose it again. If your suspension works fine after you connect the link, no adjustment will likely be needed, although you may want the dealer to check the calibration before you use the highest settings. If your Spyder does not adjust when running, in gear, with the parking brake off, or it shows "Manual" when you hit the switch, it will need dealer intervention...although it can be adjusted manually.Thank you for the info. Our dealer is 175 miles away and I hadn't expected needing to bring it back after one day of ownership. haha
I was planning on having them send me the bolt and installing myself but it sounds like they may need to do some adjustments after it is connected.
Scotty, would or could this be the reason we felt we had no suspension in the rear?
Thank you,
Jon
You should always maintain at least 10 psi in the airbag to prevent suspension damage. See the comments about leaks above. Severakl possible sources of leaks, but the Shrader valve is the most frequent.I Have the Manual Rear suspension (No Compressor ) and After I pump it to 30 Pounds (For 200 Pound rider and No Cargo or Passenger) within a few minutes its down to Zero.
The shock absorbs the Bumps OK and I go on some Pretty Bad back roads. I did have to adjust the low beams Down because the rear is probably 1/2 inch lower than the 30 pound setting.
Handles back roads and Highway excellent But I,m wondering if an Elka rear shock would be beneficial?
Is it hazardous to ride SOLO with no pressure in the Bag???:dontknow:
