Is there a way to adjust the amount of air in the rear air shock that the nanny won't promptly correct?
I was reading in the "User's Guide" that on the base model RTs, the rear shock's air can be manually adjusted for a softer/ firmer ride.
On the RTL, it is all automatic, but it doesn't say anything about how the "ideal" setting is achieved.
I find the rear shock to be slightly firm, and I want to soften it up a bit. Will letting a few pounds of air out achieve this, or will
it simply add more air automatically? If it does, is there a workaround?
I'm running around 26 psi in my rear tire.
Thanks!
--Exco
Thanks!
--Exco
