robhowen
I have a 2015 RT-Ltd with the automatic rear air shock compressor. I keep my setting on the next to the last top bar (firm vs. soft). I used to often hear small amount of air being added or released. In fact it was so often I wondered if something was wrong. Other postings seem to indicate this is normal. For the last several weeks I seldom hear this. If I use the console switch to increase stiffness or decrease stiffness nothing seems to happen. By nothing I mean I don't hear anything or feel the bike raise or lower. I use this so seldom that I don't know if an adjustment should be felt immediately or not. I have no warnings or alerts. If I test the PSI via the under seat air valve it reads about 24 lbs. I have ordered a new relay in case that is the problem (and others suggest having a spare anyway). I'm covered under warranty and will take it to my dealer (about 1.5 hours away) if I can get certain that something is actually wrong.
Can anyone tell me a sure fire way to determine if my air shock compressor/system is actually working and/or if something is really wrong?
Thanks,
Rob
Thanks,
Rob
