If you're talking about the '
New 3-piece Sway Bar' from BajaRon, whatever makes you think it needs that much space underneath it?? :dontknow:
The reason the earlier style bars needed that much room is because there's a 90° bend in each end, and about 5-6 inches of bar protruding that the Heim Links attach to.... so to get
that bar in/out, you need the height so you can thread the bent end bits thru the channel in the middle of the frame under the Spyder. With the New 3-piece bar, the spring steel section (that equates to the middle un-bent bit of the older style bar) simply slides straight in, cos it's a straight bar! Then, and only then, do you fit the solid End Links, the bits that equate to the cranked/bent section on the old style bar which connect to the Heim Links - from what I can see, while you might want to raise your Spyder
a little in order to make reaching/working underneath it a bit easier,
there is absolutely NO NEED to raise your Spyder 24" off the ground to fit the New 3-piece Sway Bar that has a STRAIGHT centre section! :lecturef_smilie:
Altho
it is true that if you don't want to cut the old/original bar off, then you'll need to raise your Spyder that high or there-abouts in order to 'un-thread' the
bent bar
