I have a 2014 RTS-SE6 and the radio stations do not come in clear. Does anyone have any suggestions?
Deanna
yes, I will check to see if it under warranty. I still a lot of warranty left. DeannaCheck to see if its under warranty.
What kind of IPod do you recommend?Agree and simply suggest an IPod or similar setup you can control via the left grip switches.
PK
What other similar set up do you recommend?
Deanna
Deanna
Check the settings. any of the bass/treble can afffectI have a 2014 RTS-SE6 and the radio stations do not come in clear. Does anyone have any suggestions?
Deanna
Deanna
Sent Pm. DeannaHi Deanna,
I'm assuming you do not own any Apple devices?
The owners manual will tell you what is compatible with the radio. But the deciding factor is the BRP plug that comes with the Spyder is of the 30 pin variety.
Pretty much anything Apple that uses the 30 pin should work. From my understanding you can use a 30 pin to lightning adapter (must be Apple branded) and make any of the Apple lightning connected product work.
My solution was to find a used 8GB Ipod Touch at a pawn shop that way I could test it there to make sure it works.
I paid about $50 for it. The Apple adapter is like $35-$50.00 depending on version.
30 pin and Lightning is Apple terminology for what plugs into the bottom of the device.
Using the Apple branded products the bike allow you to control the device via the controls on the left handle bar.
All other MP3 devices use a different input and is not controlled by the bike, only the device.
Hope this helps?
Sent Pm. DeannaDeanna, I have heard of more than a few people who have had radio troubles on their 2014 RTs maybe you should ask your dealer to start a case and see if BRP will swap it out for you.
I will check, Thanks, DeannaCheck the settings. any of the bass/treble can afffect
