Radiator fan relay failure
barb36jack31
Was riding Spyder home the other day it started to run on one culinder.(My assessment). It had a low oil light and a high temp light. I limped to a place where I could inspect the proble. Oill evel was a bit low but still well up on the stick. I let it sit for about 45 min. and added a bit more oil. Fired right up and ran perfectly as long as I was moving smartly along. If I had to wait at a traffic light, the temp would rise to the 6/7 bar position and the engine would revert to limp mode. Rode it to my dealer in a series of starts and stops. (5 miles). I was not two sentences into the explanation of the problem when they announced that the fan relay had failed. They said it was a 5 min. fix. Actually it was only 4 minutes. They plugged in a new fan relay and the whole problem went away. I plan to have the mech show me how to replace the relay. Then I will purchase a spare and carry it on the Spyder with me.
I am developing a certain feeling of mistrust about my bike. What if I had bee 200 miles from home when this all happened? I guess I am used to bikes that run and run with little or no problems. This one seems to be fairly fragile. I wonder what next is on the horizon.
Relay just plugs in.... no big deal. I picked one up at my local auto parts house.
Most riders do carry a spare relay and a few fuses to boot.
don
Those relays are easier to replace than the fuses that are in there with them. Being some folks have had problems with the relays working loose, I wonder if yours was actually bad? Just re-seating it may have taken care of the problem. :dontknow: At over 21,000 miles in all temps and weather conditions, I would not consider my Spyder fragile.
