R-35 Saddlebag Question
ABN350F
I have the Corbin Full Face helmet trunk and Im considering the R-35 Saddlebags. Does the Corbin trunk interfere with repositioning the turn signals when mounting the R-35. Just wondering if any has or have seen this set up. You may ask why the R-35 well price and because the Corbin Saddlebags are not removable luggage.
Any thoughts?
Thanks.
If you go to Corbin's website, they state in the fit note that the canam givi bag mount will interfer with the trunk, because of where the turn signals are relocated. One thing you could consider is adding the Givi R35 bag LED light kit from ESI. They can be used as additional turn signals along with your original turn signals, as well as additional lights and brake light with the proper wire harness. You can also eliminate the turn signal stalks from the mounts and just use the bag lights as your main turn signals. Evan from ESI can give you more accurate information in regards to this setup. Without the stalks the Corbin trunk would fit in place along with the Givi bags with no problem I'm sure. I have the Givi bags with the ESI light kit and the Corbin Smuggler trunk. I like this setup for myself. I can tell you that those turn signals from ESI are really bright. Just a thought to consider!
http://corbin.com/can-am/ca1hbox.shtml
I use the ESI lights on the R-35 bags as tail lights (running lights) which are on all of the time. They are fabulous for this purpose, even in the daytime.
At night, I want all of the illumination I can get, for safety. Maybe you should consider selling the Corbin top box and getting a Givi V-46. Admore makes LED lights for the V-46 which function as directional lights, tail lights, and stop lights. They are great. ESI doesn't make lights for the V-46.
