R-35 Saddle Bags
Saddle bags removed
Here is a photo of my ST Ltd with the saddle bags and carriers removed, hope this gives you some idea what it would look like.
I would really like to remove the signals and stalks altogether and use the brake lights as run/brake/turn, but it looks to be too much work...
You can get a rear light set that fits into the reflector area at the rear of the Givi bags and I'm sure I've read somewhere about a gadget that can turn your rear lights into turn signals as well, have a look on the Custom Dynamics site.
http://www.customdynamics.com/can_am_spyder_accessories.htm
You could add one of their 3rd/middle brake lights and use that as you only brake light and take the wire from your indicators and wire them to your existing two brake lights, removing the brake wires first of course, hope that makes sense.
Does anyone please help I have this saddles bags on my bike and for theove if my life I can't remove the left side turnsingle mount so that I can remove the plastic to get to my battery I need to swap it out and I just can't figure this out.
Thank you
Juejue
Thank you
Juejue
Check out this installation video.
It’s on a ST but should give you
a pretty good idea how they are
mounted. Good luck
Dennis
https://youtu.be/aQ7lqRmP2lY
