Quiz time....
RykerUSA
I go to my dealer to get my rear tire changed out. I get my byke home and I hear a sound - a rubbing sound as I roll into the garage. It is periodic which means I hear it, then the wheel rolls little further and then I don't hear it until the wheel does a full Revolution and then I hear it again.
What did they do wrong?
First correct answer gets my full respect and admiration!
it has to be !
it has too be the " comes and goes " nut adaptor that is very close too the " almost never hear it bearings " :roflblack: going to have too lift the rear end up off the ground , and roll the tire in neutral , and see the alignment of the tire it must be real close but enough too rub , in one spot ...
I would guess that they didn't get the rear wheel seated against the adjusters...
...But it sounds terminal... :shocked: Time to trade it in, and get a fresh one! :yes::yes:
I'm not sure what the right answer is yet. Tomorrow I'm going to jack it up and take a closer look and I wanted to get some good ideas before I dug into it.
I go to my dealer to get my rear tire changed out....
So that means there's a good chance you had another Kenda fitted, right?? :dontknow:
If so, a fairly high percentage of that particular brand of 'tires' really don't ever qualify as being truthfully called 'round' or of running true, so there's a good chance that the tire is rubbing on something even if everything else IS true & aligned properly!! That's probably even more likely if you have one of those a/mkt belt guards fitted on the swing arm.
If your Spyder is an RT, it could also be due to low air in the Rear Air-bag letting the suspension droop low enough to allow the 'out of round' tire to touch on one of the under body placcy mud shields; but I reckon the 'out of round' tire (or possibly a poorly mounted tire?) rubbing on something like a belt guard or brake caliper, ABS sensor, etc is probably the most likely cause of your noise...
Be interested to hear the actual cause once you work it out?! :rolleyes:
