Ex-Rocket
Well-known member
Do you have red or amber turn signals?
Sent from my SM-T350 using Tapatalk
red only
I think you are on to something.Is there any chance a converter is stashed under the trailer? My trailer is a 4 wire trailer. My Spyder harness is a ShowChrome 5 wire harness. I stashed a 5 to 4 converter under the trailer, on top of the tounge. I ran a 4 wire loop to the coupler area so I can use either 4 or 5 but if I had not done that, the brakes wouldn't light using 4. The fact you have a red wire in there sounds like a converter exists somewhere.
It's great you found the culprit! Just cut it out and splice the four to the four and you should be good to go!Lucky YOU are the MAN.:2thumbs::2thumbs: I got to digging into the trailer wiring and I found a 3 to 2 converter buried. Ok, now the question. Can I just cut off the converter and then just match up the wires, white to white, yellow to yellow, green to green and brown to brown? Also took a couple of pictures to show everybody what I got. I found the converter tucked into the tongue area of the trailer. I know I'm not done yet but hopefully their is a light at the end of the tunnel.
View attachment 143349View attachment 143350
I usually solder wires together and seal them with heat shrink tube. Solder is cheaper than connectors, and more guaranteed to have good electrical continuity.You found the culprit. Just cut it out and match the wire colors. The red will not be needed.
As for wire splices. See how it was done before. With insulated butt connectors. That leaves the connections open to water and can cause corrosion. That can give you trouble down the road. I use butt connectors too, but I fill them with dielectric grease before I crimp them on and cover with heat shrink tubing. That's just a suggestion.
I bought an old trailer a Goldwinger was getting rid of. My RT has the CAN AM hitch and trailer plug installed by the local dealer. What I don't understand is
how does the Brake/Turn signal work off of the same wire. The old trailer has separate wires for break and turn and the Can Am plug has one wire for both.
I dont want to try and hook up the two until I understand it fully. Any help would be appreciated.
That's probably because historically trailers were pulled only by big bikes, of which most of the long lasting ones were of Japanese or European origin. Those two countries mostly, if not exclusively, use amber rear turn signals. I suspect the bike designers liked the amber rear turn signals for greater visibility. Hence the trailers were made with amber turn signals to keep the wiring connections to the bike simpler. Compatibility with other tow vehicles was a non-issue since the small trailers would seldom, if ever, be towed by anything other than a motorcycle. In a sense BRP is the one that has bucked the tradition. I wonder why. Maybe North Americans just don't like amber rear turn signals. I wonder if it's a reflection of an attitude, "We didn't have amber turn signals 50 years ago, we don't need them now!"For some reason makers of trailers to pull behind a motorcycle use amber turn signal lights. This makes motorcycle trailers incompatible with most tow vehicles.
