BajaRon
Well-known member
This time of year I get a lot of questions about oil. Though some view this subject as :bdh: the oil you use is very important, people do have legitimate questions and it is worthy of factual discussion.
Everyone seems to have a bias when it comes to oil, and I have mine. The key is to base your bias on good information.
Here is a great article from 'Bob Is The Oil Guy' who, as far as I know, is an independent expert on lubricants. But regardless, it's great information.
This article deals with 'Shear' which is probably the biggest oil issue in a Spyder other than proper clutch lubrication (slippage). Our Spyders are heavy. If you add a 2nd rider, a bunch of luggage and or a trailer, you really increase the stress on the transmission. Now the Spyder transmission is more than capable of handling the added load, but is your oil up to the task?
Since the engine oil also protects the transmission and lubricates the clutch on a Spyder, this is important stuff.
Shear is murder on oil. And transmissions create a great deal more shear than an engine does. It doesn't do any good to run an extended change interval oil filter if the oils viscosity and lubricating capability has been rendered ineffective due to shear.
Hope you enjoy the article.
http://www.bobistheoilguy.com/oilshear.htm
