PMK
The oil is not leaking from the oil fill/ dip stick cap. I'm tempted to pull the right side plastics so I can get a deeper look inside the engine bay.
I may first drain the excess oil to see if the problem persists before I actually call the dealer.
Thank you!
Without doubt, reset the oil to the correct level, clean the mess and see if the concern reappears.
Based on helping others with similar issues of overfilled oil and resulting oil leaks, the typical leak location is the oil filler, which you state is not the source of the leak. Downside of the oil filler not being the source of the leak is that owners with oil leaks, not from the filler, most times require a new engine, or in some cases the warranty fix is applying an epoxy “patch” to the porous engine case area.
In simplest terms, unless assembled incorrectly with a leaking gasket surface, the 1330 engine and gearbox have no other leak prone areas, since the engine and gearbox have the one breather, the rest is sealed.
Possibly the plastic engine part, such as the filter housing is cracked?
Best to adjust the level, clean it up, and reinspect, or take it in for warranty.
All the best with it, however you decide to move forward.
