stutzmason
After a mile .... it does it
What did you end up doing ....Tire pressure, different tire?
check to see if they are too close or too far away, there is the specs written on the swing arm above the rear tire sensors, you may to shim them or something. does it do it the whole time or after a mile?
If it does it after a mile then the tire is out of spec, you could play with more or less air if its on the bubble. I put too big of a tire on and after a mile it would fault.
