Interesting ..... since the SE trans will automatically downshift ( there is no way you can prevent this ) ....How is it possible to damage the clutch by running it at low revs. ... I'm very interested on how this could occur, I don't want to damage my clutch...... Mike :thumbup:
You probably won't Mike! :thumbup:
The clutch on
your 2014 RT's
SE6 is an 'electro-hydraulic' clutch that is computer controlled/solenoid operated but 'engages' based on oil pressure, so just as long as your engine is running & has suitable oil pressure, your clutch engagement will be fine at low revs - BRP pretty much had to do this to allow the clutch to handle the significant amount of low down torque delivery from the 1330 Triple engines. And so far, it looks very much like this is something they've got really right! :clap:
However, this is not the case on the
SE5's fitted to the V-Twin engines - as BajaRon mentioned!
They DO have a Centrifugal Clutch, and it relies on
revs to engage - it should be fully dis-engaged at idle, or about 1200 rpm, then it
starts engaging at around 15-1800 rpm, but isn't
fully engaged until something like 32-3500 rpm; altho I have seen some that could easily support the argument that they don't 'fully engage' until saaay 3800 or maybe even 4000 rpm!! :shocked: Premature wear?? Maybe... :dontknow:
And as BajaRon also mentioned, on both the SE5's and the SE6's, the actual 'clutch packs' are pretty much the same as those on the respective manual clutch machines, and the gearboxes themselves are essentially the same; it's really only the 'clutch operation' that's different - and functionally, it's only the SE5's that are
really concerned about revs to avoid clutch damage due to that particular clutch being operated by centrifugal force.
BUT, the 'high revving' V-Twin engine really doesn't have a heap of grunt down low and doesn't like being asked to deliver torque at low revs, so even if you have a manual clutch SM5, you would be smart to avoid lugging the engine & trying to feed any torque thru to the driveline at revs that are too much less than those you
need on the SE5's - doing that too much will put a
LOT of unwarranted stress on the engine internals and can damage things in there pdq, even
with the computer/ECU trying to
limit things like pinging & injector knock.... :banghead: . Besides, the stock engine runs at it's 'most efficient' somewhere between about 3800 & 55-6000 rpm, so why would you want to spend
too much time running your V-Twin
outside that rev range anyway?!? :dontknow:
But just like everyone else with a 1330 engined Spyder, you really shouldn't worry too much about the clutch on your 2014 RT SE6 Mike
There again, just like any other vehicle with a mechanical/physical clutch that engages an engine to a driveline, there is
always going to be
some 'slip' that occurs at/on the point of engagement, it's apparently got something to do with the basic laws of physics - an object at rest & all that stuff - so being just a
little 'mechanically sensitive' and avoiding lugging around
AT whatever revs give you your clutch's 'point of engagement' is not really a great thing to do if you want to keep things working as they should for as long as they should.... :lecturef_smilie:
