I have a 2008 GS with an Elka rear shock. I'm trying to remove the rear tire using the technique that Lamonster uses, by removing the lower bolt from the rear shock. I'm having a hard time getting the bolt out. I've removed the nut and jacked up the whole bike so that the rear tire is just touching the ground. The bolt should just slide out, but it seems to be binding like it is under pressure from the shock or the bolt has been bent slightly. The bolt will turn, but doesn't want to slide out. Is there something that you have to do different with the Elka shocks? Any help would be appreciated.
