Does the IPOD keep charging while the bike is off?
My iPod Nano Gen 5 picks up right where it left off, right after the engine starts.
Your question got my curiosity up. I went to the garage and plugged my iPhone into my Spyder and didn't get any indicator on it's face. I then turned on the key and the iPhone responded and indicated a charge icon in the upper right corner. I then cut the key off, and immediately lost the "Charge Icon". I'd say a safe assumption is that it doesn't charge with the key OFF.
Mine has never drained my battery, even when left for weeks at a time. Better have your radio checked. That is the most likely cause of your parasitic loss.Yes the bike dose keep charging on my 2012 in the iPod in put and will draine your battery be wacht full..
I have a I Pod 6th Gen Nano
It appears to still be charging up after I switch off my Spyder RT-S SE5 2010 Model
After switching my Spyder off - If I check the I Pod in the trunk the display appears to be off (Blank)
Its only when you press the ON/OFF switch you see the closing down sequence running
this would suggest the I Pod was being charged up'd
Even if I haven't used the Spyder for a couple of days the I Pod will start at the same point it had stopped once the Spyder is switched on
I hadn't considered that this could drain the Spyders battery down but the drain must be very low so it may not be
a problem anyway
Anyone know if having the I Pod being left on charge all the time will effect the I Pod e.g Long term battery life on the
I Pod shorten'd due to it be charged up for so long and not allowing the I Pod to run down fully then being recharged
Eddie Sheppard
Reading UK
Any one use the Ipod Shuffle on the bike? Trying to find out what is best, the Shuffle or Nano before I get a new one.
